Simple oil change......a vent
I did my 3 hole oil change today. No biggie, right? At 7500 miles how bad can it be? Previous owner had it serviced at a dealer at 5k. That was the problem. The damn dealer. Oil filter took close to an hour to remove. The freakin' mutant must have tightened the oil filter with an impact gun. I actually had to use a breaker bar on the oil filter wrench to get it to turn. (counterclockwise, for those who would toss that out, lol) In my 30 plus years of doing my own services I have never, ever came across a filter so tight. I did replace it with a KN filter with the 17mm nut on the end. Next time it will be much easier.
No, just the nature of the item being dealt with. I have a dedicated toolbox drawer with every type filter removing tool made and you still get those you have to destroy to get off and many of them I installed myself. Some will act right others will bring the harsh language, no pattern to it I've ever found.
The following 2 users liked this post by TwiZted Biker:
anthony_b. (07-01-2018),
PirateRider (07-02-2018)
I have always worn a pair of rubber gloves when changing my oil and filter. I take the filter off with my rubber glove and put the new one on with the rubber glove tight. A little oil over the seal about 1/4 cup of oil in the filter and on it goes hand tight. 14 different Harleys probably 100 oil changed no leaks ever. It's that dam wrench that someone wants to sell you. My cars, truck, Jeep, and boat all the filter are on hand tight and none of them leak, you know what you can do with that oil filter wrench right.
Oil changes guys can't agree on how to do it or what oil to use when doing it. Got to be the biggest disagreement about having a Harley-Davidson.
