UltraCool oil cooler- not exactly what I was expecting
Old 09-12-2018 | 08:49 AM
RHPAW's Avatar
RHPAW
There's no mistaken notion about how much better my Shovelhead likes to run on a cool night.
If it makes you fell better about the care of your engine, you do it. First bottom-end work on that shovel was at 164,000 miles, so it can't be a bad thing.
  #32
Old 09-12-2018 | 08:51 AM
Uncle Larry's Avatar
Uncle Larry
That sure is the truth ... A cool evening is definitely a an asset to a great ride on the Ol' Shovel
  #33
Old 09-12-2018 | 01:29 PM
Walter White's Avatar
Walter White
Interesting setup thanks for posting. I may be adding some more oil cooling in the near future.
Out of curiosity anyone ever measure how much temperature lowering happens when the motor goes into one cylinder (parade) mode? The TC 110 goes into it often in stop in go traffic even in cooler weather.
  #34
Old 10-16-2023 | 04:26 PM
JR5150's Avatar
JR5150
Stage II
Hey @Bluraven ,
I know this is an older thread, I am a new member so I have not caught up on the entire thing yet. I apologize if I break some etiquette by referencing a message that is 5+ years old. I am also considering put the same oil cooler you referenced in the opener of this thread on a 2009 Softail. Can you tell me how far it sticks inside the down tubes of the frame. My exhaust system has abnormally big O2 sensor that is barely an inch away from the frame. If it is all on the outside of the frame I am good, but if it sticks too far into the inside I am hosed. Thank you.
  #35
Old 10-16-2023 | 09:13 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Some pics from the web...
Attached Thumbnails UltraCool oil cooler- not exactly what I was expecting-ultracool-pic.jpg   UltraCool oil cooler- not exactly what I was expecting-ultracool-pic2.jpg
  #36
Old 10-22-2023 | 07:02 AM
HKMark23's Avatar
HKMark23
Originally Posted by JR5150
Hey @Bluraven ,
If plan "A" doesn't work for you due to location, you might consider relocating your oil filter.
  #37
Old 10-22-2023 | 07:59 AM
CaffeineBuzz's Avatar
CaffeineBuzz
oil relocation may drop the temp 5 degrees or so… but it’s real benefit is that it’s not in the dumb ****ing spot Harley put it originally
dk customs for oil cooling and relocation…
  #38
Old 10-22-2023 | 08:34 AM
HKMark23's Avatar
HKMark23
Yep, when I measured at the time of the modification the temp drop was no more than 5 degrees. Still, there was a "drop" and changing, (cleaning in my case), oil filters is a lot less messy now.
CaffeineBuzz (10-22-2023)
  #39
Old 10-22-2023 | 09:48 AM
CaffeineBuzz
Oh yeah I agree…there is a cumulative benefit to keeping oil cooler…once oil hits a certain temperature it is done…but it doesn’t happen all at once…anything you can do to nudge that in the right direction is a huge benefit in my opinion
and changing the oil filter the first time was still work but it was a pleasure…huge difference
i had an issue with one of the lines I ran to mine…my fault and it was an easy fix… but if you run a relocation filter… inspect lines regularly
kylebryan
10-16-2023 04:28 PM
easybiker
04-30-2015 12:16 PM
geargrinder
09-15-2014 06:45 PM
Rando
Oil Archive (no new posts)
07-18-2008 10:17 AM
djkolp
29
04-05-2007 03:58 PM
Quick Reply: UltraCool oil cooler- not exactly what I was expecting
