Power commander v tunig
Old 06-10-2018, 08:25 PM
Harley1004's Avatar
Harley1004
Harley1004 is offline
Default Power commander v tunig
Sirs,new bee here. Have a 2008 ultra classic, 3.5 Rhinehart slipons & stock jugs & heads. I had a lifter go down, and since the mechanic was getting into the cam chest for the repair, he suggested that I install S&S 570 cams, lifters, pushrods, bearings. Also installed the power commander 5.... it really runs good from 3500 to 5500 rpm’s, but the few mileage is terrible, 24 miles a gallon, and when you shift into six gear at 80 miles an hour get dogs out until you shift back into fifth gear. He installed everything, but I have a feeling he put in either the wrong cams, the wrong tune, Or both. I cannot find a power commander five map for my application. Help
Old 06-10-2018, 08:43 PM
nevil's Avatar
nevil
nevil is offline
Received 1,035 Likes on 773 Posts
Welcome to the forum.
I think you should get a real tuner. You may not find a canned map that will work with your mods. Maybe somebody here has the same setup.
Harley1004 (06-10-2018)
Old 06-10-2018, 08:51 PM
JohnMn's Avatar
JohnMn
JohnMn is offline
They're out there,, you just have to jump through a few hoops. You will need the software loaded to you lap top to make it work.
Check the top two links found here,, and spend the time you need to get it done. It is not/nor will be a simple click and feed from a link off this forum,, you will have to have the capability to find, down-load to computer, then up-load to the PCV the map you choose.
https://www.google.com/search?client...w=1440&bih=763
Old 06-10-2018, 08:59 PM
Harley1004's Avatar
Harley1004
Thanks guys. I know a REAL tuner is here in wisconsin. Fuel Moto in Little Shute ,WI. I will try a nd make contact on Monday. I am just so frustrated because of the earnest cash that I spent. Considering everything replaced, I do not know if $1500.00 was to much to pay an independant, but that is what it cost. Just want to ride, thats all
Old 06-10-2018, 09:04 PM
Harley1004's Avatar
Harley1004
I have been on that site without any luck. Thanks for the info. All they have is a map for a s& s 570 gear drive with a different exhaust and ecm
Old 06-10-2018, 09:06 PM
Harley1004's Avatar
Harley1004
And I am not sure if that map is loaded into my module or not. Will not find out until monday.
Old 06-11-2018, 07:33 AM
Robb Liupo's Avatar
Robb Liupo
Robb Liupo is offline
Originally Posted by Harley1004
Thanks guys. I know a REAL tuner is here in wisconsin. Fuel Moto in Little Shute ,WI. I will try a nd make contact on Monday. I am just so frustrated because of the earnest cash that I spent. Considering everything replaced, I do not know if $1500.00 was to much to pay an independantAc, but that is what it cost. Just want to ride, thats all
Actually, I think $1,500 is a pretty good deal. I was recently quoted over $2,500 from a Harley dealer for essentially the same work. I just replaced lifters and pushrods, that alone was over $300 just for parts. Hard to understand the 24 mpg though. What you did is a pretty common upgrade, cams, and pipes, I can't believe there is not a map for your specific configuration out there.
Old 06-11-2018, 09:48 AM
chamokie's Avatar
chamokie
chamokie is offline
Get the auto tune feature, or call Jamie @ Fuel Moto. He will set you up with what you need.
The following 3 users liked this post by chamokie:
Harley1004 (08-07-2020), leachman (08-09-2020), ScottinAZ (08-07-2020)
Old 06-11-2018, 03:48 PM
danzio's Avatar
danzio
danzio is offline
Honestly, I went round and round with the PCV and after tinkering around with it myself to no satisfaction I finally spent $400 cash money on a Dynotune with a tuner who was highly recommended by my local HD dealer. Well that was money poorly spent. The tune he gave still had the bike not running optimally, at least I wasn't satisfied. I finally pulled the PCV and put a Power Vision on with a map Jamie sent me. A few autotune runs and the bike, now with 60,000 plus miles has never run better. Oh and I put my own cams in and went with S&S 551 Easy Starts and absolutely love them. Best money I've spent on the bike. Had to upgrade the clutch after the cams but all in all very satisfied with the performance. I get around 34-38 MPG's depending on the ride.
Old 08-07-2020, 02:03 AM
Harley1004's Avatar
Harley1004
update: went with the autotune from dynojet. Learned ho to use it and fine tune the PCV . After 4 sessions of tuning, I finally have a close enough tune for 36 mpg at 70 to 80 mph and plenty of power Also went to 103 ci and 10:1 commpression. That helped tremendously
Quick Reply: Power commander v tunig
