Tire Pressure monitoring
Old 06-18-2018 | 02:07 PM
cficole's Avatar
cficole
Originally Posted by Zerk
People act like knowing is a bad thing. You can still ignore the information. If you don't want to know, why do you manual check the tires?
Assumes a fact not in evidence.
  #32
Old 06-18-2018 | 02:28 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Drivers/riders can become "obsessed" with all this new info that is constantly updating. Alarms for "low" pressure exist also.
While a periodic check might be good, having it displayed all the time can take your concentration away from job #1.
SPRINGER (06-18-2018)
  #33
Old 06-18-2018 | 02:46 PM
SPRINGER's Avatar
SPRINGER
I ride with a lot of old timers or people that have been riding for several years and they aren't as paranoid about some things that many of the beginners are.
  #34
Old 06-18-2018 | 09:09 PM
Strugatsio's Avatar
Strugatsio
Originally Posted by Redoilokie
Wait till you see what heat does to your oil levels. That'll really blow your mind.
If you really want to blow his mind, explain to him the coefficient of expansion and how the actual metal parts expand and contract with temperature changes. That'll really freak him out.
  #35
Old 06-19-2018 | 02:00 PM
cacomly's Avatar
cacomly
Originally Posted by P51Driver
Here is something to think about.
First of all I always set my pressures at the recommended pressures cold. And yes when the tires heat up from running the pressures will go up, that is to be expected.
But if you have the pressures in a rear tire going up more than they should I would look at rear wheel alignment. If the wheel isn't tracking properly you are creating additional friction which in turn translates into additional heat causing the pressure to go up higher than they would normally. Also misalignment causes excelerated tire wear.
How do you figure? Yes in a car if the two wheels on one axle are not in alignment. However on a bike if the rear wheel is out of alignment then the front will be turned to compensate resulting in both wheels running in parallel and thus no additional friction.
Originally Posted by guitarfish
On the tire there is the MAX tire pressure, which is the max that tire can hold, period. Then there is the cold PSI that the manufacturer provides, usually on the label on the bike. Inflate to recommended cold PSI when the tires are at ambient (room) temperature, then ride. The tire pressure will go up when riding, but should not hit MAX.
Actually that is the max tire pressure COLD. Pressure can still exceed that while riding
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=196
  #36
Old 06-20-2018 | 06:21 PM
Bluesrider.df's Avatar
Bluesrider.df
Thanks for the correction.
Atlaska
06-17-2015 12:26 PM
hscic
Wheels/Tires
17
06-07-2015 11:05 AM
BinIdaho
59
04-21-2014 05:51 PM
tuckertaft
08-16-2010 03:48 PM
Mac57
08-26-2007 08:16 PM
Quick Reply: Tire Pressure monitoring
