Iron Horse single bike trailer?
Old 11-02-2018, 04:37 PM
SluggoMagoo's Avatar
SluggoMagoo
SluggoMagoo is offline
Removed the cheesy chock and got the HF wheel chock installed and it fits perfect. I put the street bob in and it stands up strait with no jiffy stand or straps. Of course I wouldn't drive it that way. As for the light. Mine's full of water, YIKES. It was also corroded. I drilled out the rivets and pulled the plug. I'm going to lay some cardboard down on the floor until it rains again. I guess I'll need to find a new one. I guess I should buy some caulk too.
Old 11-02-2018, 05:26 PM
The Dude's Avatar
The Dude
The Dude is offline
Originally Posted by ppilotmike
Sorry I should have mentioned it was the single bike model. In 2010 Iron Horse went to an aluminum frame and wheels which saves about 150 pounds on the empty weight which helped on the carrying capacity. That being said my Sport Glide only weighs 700 pounds which will put me well under the GVW of 2000 pounds. The guy is asking $2500 for the trailer, I am a bit on the fence because this trailer is only good for one thing.
Good for one thing?, i have a single wide Excalibur and a double wide iron horse. They haul the bikes and also haul the kids back and forth to college. The double wide hauled my 5 ft wide sandblast cabinet, loaded the single up and took it to florida on vacation a few times. Do not even know there behind you. Only issue is if you load it you need to make sure you have enough room to drop the clamshell up front. I hauled my limited home from the dealer in the single but had to remove the windshield and antennas. Even the double wide however i do not think two limiteds would fit with the fairings. Hauled a wide glide and a Heritage just fine however.
Old 11-02-2018, 06:39 PM
SluggoMagoo
Talking
And if your handy you could driver around to sporting events with a coffee maker and a hotdog cooker and make a few bucks!
Old 11-05-2018, 08:30 AM
cacomly's Avatar
cacomly
cacomly is offline
I borrowed my friend's trailer and hauled 1,000 pounds worth of tools and stuff to a swap meet this past spring in Carlisle PA so I hardly would say it's good for one thing.
I may actually sleep in it for a few days next spring and save on hotels since I found out they had showers at the show grounds
Old 11-05-2018, 11:34 AM
BikerPepe`'s Avatar
BikerPepe`
BikerPepe` is offline
Received 3,939 Likes on 1,369 Posts
If you're not concerned about running an enclosed trailer and don't have money you don't need... picking up a used, tilt-deck golf cart trailer off craigslist worked great for me. I only trailer if the bikes broke down though and I'm living on the cheap.
Old 11-05-2018, 12:01 PM
riteway's Avatar
riteway
riteway is offline
Last year i was thinking about picking this up....But i thought about it to long? Could of got it for cheap!! Oh well,You snooze=You loose...
Old 11-05-2018, 12:22 PM
RK4ME's Avatar
RK4ME
RK4ME is offline
Received 2,323 Likes on 1,449 Posts
It looks like there's no love for Pingel or Pingel-type chocks here. I use Pingel removable chocks in my enclosed cargo trailer, and I think they're great. I also have a Condor chock that I use in my garage and sometimes in my open trailer. Although the Condor chock is handy for holding the bike straight up when it's being tied down, I think the Pingel chocks are stronger will last longer for hauling and tie-down duty.
Old 11-05-2018, 12:42 PM
murray5p's Avatar
murray5p
murray5p is offline
Just picked up my 2006 IronHorse Eagle about a month ago. It is the fixed top on it and single bike. Got a 2017 Dodge ram with 5.7 hemi. you hardly know the trailer is hooked on. Its very aerodynamic . I bought it to haul my 2016 RG down to Phenix from central Canada for a month of early spring riding. Very happy with the trailer and I phoned Ironhorse , they said they still carry all the parts I would ever need. It has the retractible legs for loading at the rear as well.
John Coyle
09-23-2014 07:35 AM
Getyurmotorunnin
03-29-2011 12:43 PM
bbqbrisket
07-21-2010 05:55 PM
UNCCHarley
05-18-2007 04:48 PM
KeithB
10-26-2006 05:44 PM
Quick Reply: Iron Horse single bike trailer?
