Garage Door Opener
Old 06-24-2007 | 03:16 AM
EasternSP's Avatar
EasternSP
Veteran: Marine Corp
Default Garage Door Opener
Got my Harley Dollars coupon for completing the MSF course a while back. Went on down to the Harley dealer and bought a garage door opener. Read the instructions and decided, Hmmmm, looks easy, I'll do it tonight. Pulled the outer fairing off the RG and cut the headlight wires and soldered in the sender unit. Before I put the scooter back together, I hooked up the receiver unit and tested it. Hmmmm, door doesn't open when I push the button on the receiver unit. I check the regular button and it works as advertised. I pull the hook up wires off the ceiling and do a local continuity check on the receiver. No shorting action like the regular button does to make the door motor work. The receiver unit has the pilot light on and it flashes when I push it to activate the door, but the door doesn't respond. I reset the receiver unit by unplugging it for about 20 seconds then holding the button in when I plug it back into the wall. Still no action. Am I missing something here or is my receiver unit messed up?
Old 06-24-2007 | 07:16 AM
vertigo14's Avatar
vertigo14
Default RE: Garage Door Opener
check your fuse?
Old 06-24-2007 | 08:02 AM
airjoe's Avatar
airjoe
You need to have someone hold the button in on the receiver while you cycle the high/low beam.
Old 06-24-2007 | 08:13 AM
Alien Spyder's Avatar
Alien Spyder
Hmmm! All I have to do is cycle the hi/lo beams and it works like a charm.
Old 06-24-2007 | 08:25 AM
EasternSP's Avatar
EasternSP
The receiver unit has a button on it so the door can be activiated by pushing the button. I can't get the door to activate by pushing the button or cycling the high/low beam.
Old 06-24-2007 | 08:28 AM
woosh's Avatar
woosh
I thought the button on the receiver unit was only for programming the receiver and trasmitter together. Are you sure the door is supposed to open when you push that little black button?
Old 06-24-2007 | 08:47 AM
T Tommyt's Avatar
T Tommyt
Did you Train the new unit
you need to push the button on your door Motor while the light is blinking hit the one on the Bike
Old 06-24-2007 | 12:51 PM
EasternSP's Avatar
EasternSP
Ok, I read through the installation instructions again and I guess I am mistaking the instructions to operate the door with the original wall button instead of the H-D receiver button.
If that is what they mean, then this job is done. Thanks for the thought and input guys.
Old 06-24-2007 | 09:54 PM
barkster99's Avatar
barkster99
So let us know if this is the happy ending you anticipated. I remember my own confusion when I installed mine. The wiring/installation part made sense, it was the programming part that baffled me. Somehow I got lucky and it justworked. Hope you're up and going.
Old 06-24-2007 | 11:35 PM
YUCK's Avatar
YUCK
We had a door opener go bad once,,,me and bigfoot roll up to this garage,,,the guy runs over and pulls the door open for us,,,bigfoot klanks in gear,,starts ripping into the garage as the door hit the stops and started back down,,,,blam hits big foot in the nose,,takes him right off the bike,,,,I drop'ed my bike laughing so hard,,,u had to see it to believe it......thats the only garage door opener experiance we had.......I gotta get that opener and flash my light as I ride by garages....
Quick Reply: Garage Door Opener
