Question about External Breather Systems
Old 05-08-2018 | 02:47 PM
Clammy's Avatar
Clammy
Originally Posted by AZRenegade
Thanks, gents. Your input was very helpful and appreciated by me. Based on what I've read here, the hose and possibly catch can is the ticket. I do a lot of high speed long distance interstate riding and the bolts might not be the best choice for that kind of riding.
Just FYI, I do a lot of long haul highway riding too, averaging 75 mph+ for hours at a time, and even before I enlarged the oil return holes in the rocker support plate, the amount of oil misting wasn't intolerable. It never got on my clothes or anything like that. just left a light coating on the air filter bracket, and carb, at times,n heheh... but, as I said, once I opened up the oil return holes, the issue disappeared.
Cheers!
AZRenegade (05-08-2018)
Old 05-08-2018 | 03:02 PM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by Uncle G.
My Evo has breathed oil vapor for over 200,000 miles with no apparent ill effects. Do what you want, but my advice is not to worry so much and ride more.
Two of us agree. Little oil actually gets in intake since what you see is the little that accumulated in the line and drips a few drips down.
Drilling the bottom of the breather only allows the incoming air to bypast the 180 turn and shoot straight up thru the screen that helps remove more oil after the 180 turn..
But the rest are alast, tin men saleing their wears or those drinking their coolaid.
Old 05-08-2018 | 03:07 PM
T^2's Avatar
T^2
Originally Posted by Clammy
I thought maybe the umbrella valves in the engine breathers were worn out, so I got the rebuild kit and rebuilt them. That didn't make a difference.
The umbrella valves prevent the intake of air, not the expulsion of it. The idea is to create a partial vacuum in the crankcase etc. So when they fail, they would fail at preventing the intake of air. The system would still be able to expel the air (and any oil/water content therein). The umbrella valves themselves have a rep (so I've read) for not lasting too long before they start to fail. That's why I added a Krankvent. Actually, from what I've read, the umbrella valves can just be removed/tossed when using a Krankvent.
Old 05-08-2018 | 05:29 PM
Jackie Paper
Default Little VENT info from Harley
One way rubber check valves out do nothing to stop any oil from coming out. There is a brief time that there can be a vacuum in the crank case
Gozzie's Avatar
Gozzie
I went with a hose, no catch can, After a day or two you wont even notice the hose is there. It doesn't drip enough to warrant a catch can.
Here is what I did https://www.hdforums.com/forum/gener...n-removal.html
Old 05-08-2018 | 06:31 PM
SWThomas's Avatar
SWThomas
Veteran: Marine Corp
I agree. If it’s such an issue, where’s all the engine failures from breathing oil vapor???
Old 05-08-2018 | 06:40 PM
Veekness's Avatar
Veekness
I went with DK's DIY kit and wound up putting the breather filter inside the right side cover under the battery... out of sight, out of mind.
DK Custom - ST (05-09-2018)
Old 05-08-2018 | 06:50 PM
Tarkus60's Avatar
Tarkus60
I bought the Breather bolts. Look cool but they are a mess. If you clean the foam every time you ride maybe, but who wants that.
So DK are straight up guys!
I bought the hose kit with the filter. So much better! But still you have to clean the sponge.
So this year I just ran the tube down the the lower frame in the front.
We have a winner....so far!
The following 2 users liked this post by Tarkus60:
AZRenegade (05-08-2018), DK Custom - ST (05-09-2018)
Old 05-08-2018 | 07:23 PM
AZRenegade's Avatar
AZRenegade
Has anyone noticed any performance improvement from this modification like better gas mileage, smoother idle, etc.? By the way, pretty slick setup, Gozzie. I might just go that route. Pretty simple and doesn't cost a lot.
Old 05-08-2018 | 07:30 PM
Tarkus60's Avatar
Tarkus60
No not really....lol
But not putting oil/water crap back in to the intake. So longevity is the key here.
Maybe plugs will last longer????
Quick Reply: Question about External Breather Systems
