LED Load equalizer question
My bike is an 01 Softail with a custom rear tail light assembly. It is LED brake light with LED turn signals built into the whole assembly. Very clean looking, but not really as bright as what I like. I should also mention that when the brake is applied the brake light will flash 3 times before going solid and everything in the rear works perfectly.
Here is my question. My front turn signals are standard amber bulbs with a smoked lens. All of the turn signals work fine----so did the previous owner have an equalizer hidden away somewhere? Or should I plan on buying that also when I change everything to LED? Since the brake light flashes, I would think one is there somewhere, but does that not affect the standard incandescent bulbs up front? They work normally.
Are there other rear signals other than the ones in the brake light? If not or there are also other LED signals in the back then there is a load equalizer somewhere. If there are also ambers in the back then there is no load equalizer. If you switch the fronts to LED then I suggest you find the current load equalizer and find out what it is as there are some that can adapt to the load needed (active) and there are some that can not (passive).
I understand. I have the same brake light. I am asking if there are any OTHER turn signals on the back other than those inside the brake light assembly.
you may not necessarily have a load equalizer. my 2013 cvo came with led signals in the rear (integrated, brake and turn), and regular incandescents in the front. everything worked fine, until I added custom dynamic signals up front. then I would get some wonky behavior. added a cd signal stabilizer and that set everything back to normal. I also have the cd brake light flasher hooked up.
