Ride-on sealent use on an existing flat?
Has anyone fixed a flat tire by using Ride-on AFTER finding the flat? Any reason it wouldn't work?
The rear tire on my Heritage (spokes/tubes) goes flat in ~3 hours. It would seem that I could put Ride-on in the tire/tube, air up the tire, go for a ride and have a fair chance of permanently fixing the leak in the tube.
Or, is this a really dumb/dangerous idea?
SPRINGER (03-21-2018)
Have you reviewed the valve?
Have you reviewed the valve cap?
How old is the tube in the tire?
I would attempt ONLY as an emergency.
If you have something IN the tire there could be a tube tear eventually and the results might be devastating.
I've been putting it my Heritage's tubed tires for years and it works flawlessly.
I've never tested it on a flat......or have I and just don't know it.
I still would pull the tire and get a new tube put in though.
Do you have a reason why you wouldn't put Ride-On in a tubed tire?
That would be a great test of the product.
The thinking is that even though it might not be AS effective, if I pick uo a nail and it gets me to a place where I can get it fixed, then it's worthwhile.
But to "fix" a flat that's already happened.....nope.
There's no reason NOT to run it tubed tires. I run it in mine, tubeless, tubed both.
