Flush mount gas cap trim ring
I had a defective gas cap for my Dyna and recently returned it. The paint had all bubbled up because the cap didn't sit right.
On this new trim ring, I notice a clear seam in it. Forget if my old one had one too and they are all like that, or I need to get another one instead.
Can someone take a look at theirs and see if this is normal?
its hard to see. I can tell you to watch the metal spring on the gas nozzle when you are filling it will chip the ring that goes around the fill hole.
Beware of those. Sure, they look cool and the route I took when I had a bike makeover with custom paint. After a year or so mine also allowed gas to get up under the paint and ate away at it like cancer. My painter took care of it but warned this is a very common occurrence. Had even done it to a bike of his own once.
The trim ring doesn't lay "flat." It's supposed to follow the contour of the tank. Since the deviation is minute, it's difficult to "clock" into perfect position. Gasoline, doesn't have this problem finding a small gap(capillary action).
I've seen ppl use a grease pencil to locate the trim ring for final assembly.
