Need suggestions on how to remove a baffle from Rush Muffler
Received 1,225 Likes
This is a slip on muffler but the baffle wasn't the size I wanted. I ran it for a couple of months as it was, and ordered/received the baffle size I wanted. When I went to remove the baffle, no matter how hard I tried, I couldn't get the thing out. I hooked a cross-member that went across the middle and pulled. Eventually it broke off. I tried hammering it from the inlet side to no avail. I went with a sawzall in an attempt to cut it so I could kind of fold it in the reduce the outside diameter of the outside of the baffle. I have enough room now where I can stick a coat hanger opened up all the way down between the mat and the body of the muffler, and tried moving it around the outside of the mat to help things along. Still nothing. I can move the metal part about an inch or so, but it catches on the mat and stops it cold. The mat itself is rusted to the body of the muffler. I think if I could remove the mat completely that would help, but there really isn't any room to get in there to pull it out.
I have been working on it for about 6 years off and on but I have yet to make any headway. I have saturated the mat with WD-40 and some Liquid Wrench to maybe help break the mat free, but to date that hasn't worked.
I do have a long knife made by Regency Swords but the blade isn't long enough. The blade is almost 11 inches long by 7/8ths of an inch wide, but I can't get it in far enough to do any good. My regular swords are plenty long enough, but the blades are too wide and thick. Something like a Rapier might work, but I don't want to invest in one just for this purpose.
That's what I've tried so far, and really I would rather be able to use it instead of pitching it or making something for the garden with it. I do have the replacement baffle around here someplace but I haven't seen it in years. If I do finally manage to get the baffle out, if I still can't find the other baffle, I could always get the Thunder Torque Inserts from DK Custom and go that route.
I'd love to hear any suggestions y'all might have to remove the baffle.
It's not that I really need the Rush muffler, I have the Cobra Tri Oval for the 2 into 1 pipe, as well as the stock muffler for the occasion where I need to sneak up on someone
DK Custom - ST (02-21-2018)
Cowboy Rob (02-21-2018)
Most slip ons I have seen removable baffles have a screw or bolt on the bottom or backside of the muffler. Remove the bolt, replace the baffle then put the bolt back in and you're on your way.
Are you sure it's a removable baffle? Some are welded in and need to be cut out.
edited to add- BTW you are either the most patient or determined person I've ever heard of. 6 years?
You can try putting it in the oven at 425 degrees for about 20-30 minutes. Might not be doable if the WD-40 that you put in there starts to smoke.
You can also use an air impact hammer to cut/chip/vibrate the baffle out. Harbor Freight sells a kit that comes with many tips. One has a V shaped tip. Try it at the point where you can insert the coat hanger. The v shape will act like scissors and cut through the metal in no time. The vibrations from the air hammer will loosen everything else. You may also want to heat the inside with a propane torch to the inside of the slip-on to break the rust and bond between the metals.
Bonnie Storm (02-22-2018)
The following 5 users liked this post by RHPAW:
Cowboy Rob (02-21-2018),
LoneWoolf (02-24-2018),
riteway (02-21-2018),
RK4ME (02-21-2018),
tar_snake (02-22-2018)
Received 49,966 Likes
Six years, 6 hours, either way that’s too damn long to work on one can. The baffle with either be bolted in, riveted in, or welded in. If it’s used, some jackwad might have slopped in a tube of JB Weld, you don’t know.
Frankly after an hour or two I’d have either called Rush, swung by my local indy, or just started hitting CL or EBay to find a new set closer to what I was looking for.
I just don’t have that kind of patience.
