High Heat Powder Coat?
You can coat them so long as it's a flat or satin black. Gloss black won't take for some reason. I had my heat shields done in gloss black and it blistered up after the first ride.
I did wrinkle black powder coat on mine ('16 RK) last year; I also wrapped the exhaust; after the 2nd/3rd ride it started to turn white and eventually semi-gloss in the area of the cat. Additionally, in the areas of the muffler where there is no insulation turned white. I'm having it done again this year with the exception being that the cat has been removed and the exhaust wrap is titanium. I'll let you know how it goes.
There is a " High Heat " powder coat, but it only comes in flat black and (according to my powder coater) is procedure difficult to put on.
My powder coat guy is doing Ceracoat now, as mentioned above it will be a flat or satin black, but then he can put a gloss clear over the base coat. Only the Ceracoat brand will handle exhaust temps and allow you a gloss finish if you so desire. At least thats what I'm told. It does get expensive though, it could double the cost of most exhaust systems.
When I blacked out my FLHX last year, I used VHT Wrinkle Black on the heat shields. Fifteen bux. Worked great. Only rated for 450°, but they don' get nearly as hot as the pipes.
Used standard VHT on the pipes, and House of Kolor high temp black on the mufflers. Would have used it on everything but I didn't have enough. I used Scotchbrite discs on a die grinder to give the chrome tooth.
A year and over 10K miles later, it all looks new. Might be an alternative for ya, OP, although I concede it doesn't answer your question.
Received 24,321 Likes
Received 15,744 Likes
http://www.vhtpaint.com/high-heat/vh...eproof-coating
Auto parts retailers have VHT paint rated for thirteen hundred to two thousand degrees intermittently. It specifically mentions exhaust on the can.
Another alternative is Jet Hot, and it's been rated highly over the years, but I did read something negative about it in this forum a while back from a member.
