oberon clutch levers
I went from a 2012 street glide to a 2017 street glide special. First thing i noticed was the distance the clutch grabbed. This was way different than my 2012. Getting use to it but would like the handle to be closer. I was reading up on these Oberon clutch levers & was wondering if anyone has any hands on using these.
If you want the engagement point on your clutch to be closer to the grip, these levers will do it. Your bike may not crank in gear with the Oberon, mine won't, even set all the way out. It may be my that my clutch switch has gone bad, but I haven't put the original lever back on to try it. Cranking in neutral isn't a big deal to me, but everyone may not feel the same.
There's a thread going on about these over in the M8 section. I picked one up but didn't care for the look as it was quite different than the brake lever ( and shorter ). I've changed the way I grip the stock lever using the end pads of my fingers instead of just grabbing a handful of lever like I normally did, and that seems to have done the trick for me. It was an adjustment, but After nearly 7K miles it now feels pretty normal to me
