Fork oil question
I have a 2006 FXDWGI and I just got some new progressive fork springs. I'm about 5'8" and 175lbs and I ride 2 up 50% of the time. I emailed progressive and they said
Spacer should be 6.9” in length.
Fork oil level/volume should be checked according to the steps outlined in your authorized shop manual. Measurement of your fork oil by level is the preferred method. However, some manuals only specify a volume measurement. Due to the design of a progressive wound fork spring it will displace more oil thus requiring a maximum oil level of 5.5" (140mm).
My question is
does the spacer length sound right?
and I believe my manual says somewhere around 29 oz of fluid per fork. Don't have the manual with me. But the 5.5" oil level they're talking about, is that measured from the top of the fork to the top of the fluid with the forks collapsed? And what would I use to measure the 5.5" without buying the special measuring tool?
thank you in advance
My question is
With your 49mm tubes you didn't specify what Progressive springs you installed; when I installed the Progressive 11-1546 heavy springs Progressive called for a 5.5" spacer and a 150mm fluid level. I weight 145 pounds, never ride 2 up, and the heavy springs were the right choice for me; not at all harsh, but firm and planted.
If you're using the Progressive standard springs the fluid measurement and the spacer length might very well be right and exactly what they told you it is![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
The fork oil measurement specified in the SM is out the window with non OEM parts. Follow Progressive's recommendations; their springs do displace more oil and that spec in the SM which calls for a 95mm fluid height will lead to an overfilled fork tube.
You take the fluid measurement with the spring, washer, and spacer removed and the slider compressed; you measure from the top edge of the fork tube down to the fluid. You can use something as simple as a metal ruler to measure the fluid height if necessary. Just make sure the fluid height is the same in both tubes. IF you cut your own spacers out of PVC be certain the spacers are clean and free of any debris from the cutting; that debris isn't something you want in your fork tubes...
thank you
and I got the standard springs 11-1525
I think maybe I should've gotten the heavy duty?
