handlebar slippage
handlebar slippage
I recently put a modest set of 12 in apes on 2 in risers on my 05 Niigh Train. I Love em. Well, after carefully installing and torquing down bolts with blue locktite, they still move somewhat when a go into a dip or they are jarred somehow. i don't want this to become a safety issue. the risers have caps that cover clamp bolts. should I run a set screw or something down each riser to reinforce?
Thanks in advance for all advice,
Ron
Ron
Received 2,087 Likes
Did you use the correct torque spec? Or did you just "torque them down"? I've adjusted several of them, and the only time that they ever shifted was he time that I didn't use a torque wrench, and just used "German Torque" (Guden tight".
I had a set of bars that would move if I hit railroad tracks or pot holes hard enough. I noticed that each time a little of the chrome finish was peeled off from the underside of the clamp. I did the same as you and sanded it with some 80 grit to give the underside of the clamp a good, rough, texture for the knurling to bite. Never had an issue after that.
