Legitimate oil question
Old 10-18-2017 | 05:43 PM
big- mike's Avatar
big- mike
Default Legitimate oil question
I have a friend of mine that has a few cases of old school gtx racing 20w50 racing oil I'm sure it has zinc in it will this be a problem in a 103 twin cam? Btw I do not run synthetic now I'm thinking the zinc content would be good for the bearings. Any opinion?
Old 10-18-2017 | 05:57 PM
lh4x4's Avatar
lh4x4
If it is five or more years old dump it.
Old 10-18-2017 | 06:17 PM
farmboy555's Avatar
farmboy555
Use it in the engine Don’t dump it
Old 10-18-2017 | 06:18 PM
big- mike's Avatar
big- mike
Why is that I'm sure the are all sealed
Old 10-18-2017 | 06:26 PM
TORQUEY's Avatar
TORQUEY
^^^...or fill the chain saw reservoir with it...^^^
Old 10-18-2017 | 06:27 PM
Iron lHorse's Avatar
Iron lHorse
Why would you say dump it ? It's not a 5 year old can of beer !
Old 10-18-2017 | 06:44 PM
jz78817's Avatar
jz78817
use it. all of the "V-twin" motorcycle oil you can buy off the shelf right now has a ****-ton more ZDDP than motor oil for a car. Bikes don't have post-cat O2 sensors, so if the phosphorus poisons the cats no one is the wiser.
edit: to clarify, as far as the engine is concerned, zinc (ZDDP) is a good thing because it's a potent anti-wear additive. ZDDP has been progressively reduced from car motor oil because it can make its way into the combustion chamber and poison the catalysts. and cars have downstream (post-cat) O2 sensors to make sure the catalysts are working.
Old 10-18-2017 | 06:48 PM
Ddieselsmoke's Avatar
Ddieselsmoke
If you knew how long it sits around in giant tanks it wouldn't matter. Have you ever seen an expiration date on a quart of oil?
Old 10-18-2017 | 06:50 PM
bklynbob's Avatar
bklynbob
What is the SAE rating and does it meet the diesel rating that Harley specifies? Many Racing oils have a limited additive package and aren’t meant for a street bike. Ya might get away with using it but wouldn’t go more than 1500 miles ona change.
Old 10-18-2017 | 07:02 PM
Tommy C's Avatar
Tommy C
Oil in a sealed container has no expiration date.
Quick Reply: Legitimate oil question
