CoPilot - Route Planning Options
Old 10-03-2017, 06:42 PM
T^2's Avatar
T^2
T^2 is offline
Received 1,180 Likes on 732 Posts
Originally Posted by Jeevz1
Try myrouteapp.com it can be accessed on a PC, phone or laptop as long as you have a signal. Also has the convenience to save the trip as a Harley compatible file if you have navigation.
Before I got the Infotainment system I used CoPilot also, didn't like their inability to transfer maps across systems either.
I've tried myrouteapp.com. It has it's own limitations. First, it doesn't support a direct export to .trp. You have to export a .kml file and then convert it. The end results are not really desirable either. When you load the map into CoPilot you get a gazillion waypoints that make up the route. I've seen no way to control this. You can control this in the options/web-apps that I posted in my original post.
Old 10-03-2017, 07:17 PM
dandrumheller's Avatar
dandrumheller
dandrumheller is offline
When I export as GPX then convert to trp I get the same waypoints I originally set...
Old 10-03-2017, 08:25 PM
T^2's Avatar
T^2
T^2 is offline
Doesn't work that way for me. I get a gazillion waypoints in the .gpx file. Same as with the .kml file.
Old 10-04-2017, 09:42 AM
dandrumheller
Weird.
Edit: See what you see with this one. Simple 5 waypoint loop made on mapmyroute.com, and saved as GPX 1.1 file.
https://drive.google.com/open?id=0By...jRvWFN0OTZfZ3c
This is what it should look like:
This is what it looks like when uploaded to the converter:
And after conversion:
And here's the completed .trp file:
https://drive.google.com/open?id=0By...Th3M1k1SGFiQm8
Old 10-04-2017, 06:30 PM
T^2's Avatar
T^2
T^2 is offline
Weird.
Apparently my problem was the RouteConverter Android app. When I used the RouteConverter Java app on my PC it worked fine. The only problem with the Java app is the font size in the application. Hard to read the menu's etc. Don't know how to fix that other than to change monitor resolution perhaps.
newmanb138
04-21-2016 08:53 PM
Kenney
04-10-2016 07:26 AM
jacknthebox
06-24-2012 04:51 AM
Ron750
04-26-2012 02:22 PM
AtticusFinch
07-08-2011 01:39 PM
Quick Reply: CoPilot - Route Planning Options
