Adjusting auxilliary lamps - special socket - Where do I get it?
Does anyone sell that special socket for use on the auxilliary lamps on the touring bikes? I know it's got a notch cut in it due to a wire that obstructs the nut for loosening the lamp/clamp or whatever... Who makes one of these? Seems to me someone makes this socket and I know some of you have even made one also.
Thanks
Thanks
RE: Adjusting auxilliary lamps - special socket - Where do I get it?
pull the wire out of the lamp..
tighten the bolt under there
push wire back down through
or... haha get out ur drill and drill a long socketed 1/2inch socket.. make a nice hole, file the edges so the wire wont shaft when u pull it through, push it up with the wire hanging out of the socket and tighten the ****...
if the nut is dropping down into the socket too much.. stuff some paper in there..to act like a driver..
and of course I didnt read ur whole post through.. hehe
dunno who sells em, i made my own...
guess u could instead.. make a nice slot in a 1/2 socket ...heh better have some decent tools to make it... maybe a plasma cutter (muhaha)
and slit half way around (so its not too weak)
the hole in the socket thing is only really good for installing a new one which isnt wired up yet...
I been googling it, cant seem to find what I am asking google heh
heheh if u got really creative you could spiral cut a 1/2 in sized socket.... so when you pull the wire down as you twist up it wont get twisted as you tighten or loosen the nut...
heh thats a lot of f'n effort tho... but could be done
how many times did I reply to this question.. i should take a picture of my drilled socket and post it...not tonight tho
Thanks guys, I know some have made their own adn it seems to me maybe Snap-Onwas the company. Maybe I can do a search at their site and try and find it. I'll take any donations for the cost, hehe
i usually adjust mine gently with rubber hammer.
Snap On sells them for about 25.00 each.
I just went to the pawn shop and got a 9/16" deep socket and cut a slot in the side of it with a dremel tool. Took about 5 minutes and cost 1.00.
If you get a 1/2" socket, you are going to have to do it twice, because the proper size is 9/16".
Bill
Bill
Did the same thing...but made a perpendicular cut also...ends up with a "T" shape...allows for a little movement when tightening. The Snap-On part you are looking for though is
http://buy1.snapon.com/catalog/item....mp;dir=catalog
doh 9/16..wth was I thinking 1/2... bad to post when ur falling asleep
dang I looked on snap-ons website and I couldnt find that ... thanks
