Something to ponder
Something to ponder
So to preface the question to hopefully ward off some of the obvious comments.
Yes, Have the shop manual.
Yes, I have been wrenching for a good while.
Now, the question to ponder, when servicing the front wheel, which do you tighten first, the axle nut or the pinch bolts?
Oh, and yes, it's still riding weather here so I am not bored
Received 5,760 Likes
Ponder this...
I was taught this in Kenny Roberts pit many years ago...
When tightening up the axle, spin the wheel in the direction of travel, squeeze the brake lever and hold it. Then tightening axle to spec, then pinch bolts to spec. Then release brake.
What this does is remove any "mushiness" in the brake as all the slop is removed from the mating surfaces (in the direction of travel.)
Works for both wheels.
Ponder this...
When tightening up the axle, spin the wheel in the direction of travel, squeeze yhe brake lever and hold it. Then tightening axle to spec, then pinch bolts to spec. Then release brake.
Ponder this...
