Tar Snakes
RE: Tar Snakes
Hey Jerry, if it weren't for the totally diff. scenery, I'ld swear I've seen that road up here
The one I dislike the most, has alot of those snakes, as well as deep unfilled cracks running parallel to the road, thru almost every curve.
It was a beautiful backroad, leading up to a very scenic Hatcher's Pass, AK. Then last fall, the severe floodingin the Susitna river basin, musta really tore up the road surface, cause when I took a ride thru there, I swore, never again [][:'(]. At least until it's repaved or sumpin'.
RE: Tar Snakes
I HATE them things!!! Bad enough that it affects traction, but it also throws up little spits of tar all over my scoot [:@][:@][:@]
Here in Delaware, we've also got a LOT of compression ridges going across the main roads that scare the $hit outta ya when you hit them unsuspectingly [:@][:@][:@]
RE: Tar Snakes
ORIGINAL: DirtyDave
They are as much fun as a cattle grate on a curve!
RE: Tar Snakes
ORIGINAL: middleman
I had my first encounter with snake tar this past weekend in Cincinatti. It was 90* and I'mcoming arounda curve 2-up with Tbag full.The backendkicked out. Istraightened the bike best I could and struggled to keep it on the pavement. I wish I had read this post before that. I didn't know they were slick in heat/rain.
RE: Tar Snakes
Oh man..we have those on a twisty road I used to frequent around here. It's a real mess..very sloppy and all over the place - especially in the curves. NC DOT doesn't seem to care.
RE: Tar Snakes
ORIGINAL: celtlion
RE: Tar Snakes
My best friend went down recently due to the superior intelligence exhibited by the DOT in the state he was riding in and the ability of the DOT in that state not to give a $hit about bikers or road safety in general.
Bitter you ask...????
Damn right I am.......locally there are cracks and craters that are enough to take the front end out from under a bike if hit the wrong way. I live here and have learned for the most part where those dangers are. Bikers passing through or those unaware are in for it though. Well spent tax$ if you ask me.
RE: Tar Snakes
Actually the purpose of the tar snakes you are talking about is called crack sealing. It seals the cracks in the roadway to keep moisture from getting between the asphalt and the road base which causes poholes and ruts. I don't like them either but it is better than potholes and ruts.
