Should there be a gasket between the head
pipe and the heads? When I changed my stock pipes all I found was a retainer ring....Shouldn't there be a gasket?
RE: Should there be a gasket between the head
Yep, there is. It is a graphite gasket that fits into a recession in the head at the exhaust port. You have to look real close because it blends into the head due to it's color. It is a soft gasket that conforms to the flange on the pipe. I think if you look closely you will see it.
ORIGINAL: Bowtieman31
https://www.hdforums.com/m_244292/tm.htm
Will show what the gasket looks like when its out of the port, it sits into the notch in the port pictured below.
You can dig it out with a scribe or the tip of a sharp knife.
[IMG]local://upfiles/4133/C63C1750BEDA4C20A9B0FFAE97487F00.jpg[/IMG]
