Stop light sharing.
Old 06-08-2007, 03:23 AM
Bowtieman31's Avatar
Bowtieman31
Bowtieman31 is offline
Default RE: Stop light sharing.
Doesn't bother me a bit. As stated before, two tail lights are more visible than one.
  #62
Old 06-08-2007, 06:21 AM
Ben U
Guest
Posts: n/a
I can't beleive I just read this whole thread ... [sm=WTFsgign.gif]
  #63
Old 06-08-2007, 07:32 AM
Crusing's Avatar
Crusing
Crusing is offline
It is not an issue for me. If I pull up behind another bike stopped at a light, I’ normally hang back a little unless I think I know the other rider.
  #64
Old 06-08-2007, 08:17 AM
wardenwf's Avatar
wardenwf
wardenwf is offline
No problem for me either. I don't do it but unless I know the rider. I always stop behind and to the right or left depending on their position in the lane.
  #65
Old 06-08-2007, 09:14 AM
back again's Avatar
back again
back again is offline
Received 6,411 Likes on 2,589 Posts
I never stop in the middle of the lane if there is a car in front of you.Don't care if anyone comes up in the other side and sits there either. You sit in the middle and you limit your chance of hauling *** out of there if the vehicle behind yougets shoved into you. If you do get rear ended I'd rather be driven foward past the side of the car in front of you instead of the middle of it.
  #66
Old 06-08-2007, 09:26 AM
bone2's Avatar
bone2
bone2 is offline
Good rule of thumb.
Don't EVER say hello to anyone you don't know.
nice life[sm=bangbang.gif]
  #67
Old 06-08-2007, 10:10 AM
whaap's Avatar
whaap
whaap is offline
I think it's sort of cool. Light turns green, they wait for you to proceed and you just had a pleasant encounter !
  #68
Old 06-08-2007, 10:15 AM
BeavisRules's Avatar
BeavisRules
BeavisRules is offline
I will pull next to someone if they have a nice ride and I want to give them the "approval" nod. I will also make sure that they pull away from the light first.
  #69
Old 06-08-2007, 10:25 AM
Ratbasturd's Avatar
Ratbasturd
Ratbasturd is offline
I don't mind if they pull up if I have seen them back there, what I don't like is when someone whips up next to me when I haven't seen them. When I come up on another bike at a light I pull up to a staggered posistion where I can be seen in his mirror
Years back I had a motorcycle cop that tried to slide up next to me(while rollin the lower deak of I-35) and tell me to slow down, about the same time I did a fast right hand lane change to whip in front of an 18 wheeler. I never saw him and nearly clipped his front tire as I cut across his path, I got a ticket for speedin after that, but I bet he don't pull up on people like that any more. If I would have cliped his tire it would have probably put him under the big rig.
  #70
Old 06-08-2007, 10:29 AM
HogBoy's Avatar
HogBoy
HogBoy is offline
I won't pull up next to someone unless I know them. I don't have a problem with someone pulling up next to me if they're so inclined. I don't think I'd resort to the phraselogy Dirty Dave uses, but if you don't want 'em doing it, then park it in the middle of a lane. This ain't rocket science--at least, not since I last checked.
Quick Reply: Stop light sharing.
