A way to test a battery without a load tester?
I want to get an idea of my batteries strength. Anyone have a test to gauge a battery's condition when you don't have a load tester? It's in my 2002 Fat Boy. I was thinking maybe a test like leaving the lights on for 15 mins then trying to start it? Or some test with a multimeter? Any ideas?
Take it to a Harley Dealer or an AutoZone, Checker, Shucks, Kragen, O'Reilly, etc. A Load Test is good, use of a Capacitive tester (Midtronics or similar) is slightly more accurate/predictive.
As YamaHarley implies/suggests; you can:
This test will not be 100% accurate, but neither (for a variety of reasons) is a Load Test. On the other hand, without a Load Tester (Carbon Pile) or a Capacitive Tester it'll be the best you can do in your garage at home. Also, FWIW, the (what are called ) Wienie Roaster type testers are of almost no value. Other than to the folks that sell them I suppose.
- Disconnect the spark Plug Wires and (this IS important) use a couple of jumper wires to ground the disconnected Spark Plug Wires so that the bike will not start.
- Turn every light on the bike "On."
- Put a Volt Meter on the Battery.
- Crank the engine with the Starter Motor for 30 seconds. (This is done to remove what is called a Surface Charge which can otherwise create a false positive result.) Note: 30 seconds is a long time so keep an eye on your watch. Do NOT short change the 30 seconds.
- Wait 2 minutes. (This allows the battery to fully recover. Remember that a battery creates electrical power chemically. So give it a couple of minutes to reach/restore its chemical balance.
- Crank the engine with the starter motor again for another 30 seconds. Again do NOT stoop short of 30 seconds.
Last edited by Bluehighways; 06-06-2017 at 11:41 PM. Reason: Add Pictures of Capacitive and Wienie Roaster type Battery Testers
JohnK-NJ (06-07-2017)
Yammy is right.
Here's a cheap load tester. Plug this into the Battery Tender lead and hit the start button.
http://products.batterytender.com/Ac...D-Display.html
It also fits in the tool kit nicely for on the road diagnosis.
pgrchaplain (07-05-2020)
I use one of these on all of my 8 batteries. Better than a load test for determining condition. Lots on Youtube on how to use it : https://www.walmart.com/ip/SOLAR-BA7...&wl13=&veh=sem
No Value?
Now, I would agree that the results are only as good as the mechanic is at reading them!
