Gear lube in primary?
I'm just wondering if I can run gear lube in my primary? The reason I'm asking I recently did a all bearing replacement through the primary and transmission. When I got done everything worked great except I had a drip and I do mean drip but I could smell it on the exhaust so I went back in and and replaced the inner primary seal no main shaft seal not being 100% sure where the leak was coming from. Now I'm 100% sure it was the inner primary seal. I just got back from a 200 mile ride as I went to put the bike away after sitting for at least an hour I saw a drip. My thinking is if I use gear lube in the primary would the thicker lube de less likely to drip? Now I know some would say one drip the size of a dime is normal and don't worry about it but I guess I just can't let it go
Received 4,769 Likes
Maybe your dime size leak is from left over oil you didn't get cleaned off from your first issue. Good Luck. Let's know if you find the problem.
