82 iron head advice...?
Just got 82 iron head won't start, after driving bout 30 miles it shut down while driving it. It's new bike to me this season, and am still working out kinks but this one is crucial being that the americade bike rally is in 2 1/2 weeks and need help any advice could help, iron head advice would be so appreciative.
First thing is check for spark and pull the plugs and see if there fouled. Second thing is make sure you have fuel to the carb and that when you roll the throttle it shoots fuel! Possible causes cold be a coil gone bad or a ignition issue under the cover but like I said first thing is check to see if you even have spark
What kind of carb does it have, S&S carbs can gas foul your plugs if run just a bit too rich. Do you know any history on the bike?? Was it sitting for awhile??? Does the carb and gas tank need cleaning?? How was it running before it died?? If it was running good the timing should be OK. Check coil for cracks, sometimes they run fine at first but after they get hot they lose spark. Hit up the ironhead forum.
Tks allot I have good spark to my plugs, thinking it's a linkage problem with throttle on crab maybe it all feels right but when u throttle down and watch they don't seem to be workn as a team and think not getn proper fuels. Put a lil fuel in plug ports and wanted to fire but not enough.
Received 23,856 Likes
Got a shop manual just would like a educated spot to starting place. Do my own work Lookn for some advice on starting point. Think my front cylinder lifter would cause it to not start???It was running and was driving at 55 mph when just died no sputtering just acted like the key was turned off , and wouldn't re fire back up..?
Received 4,884 Likes
