Question about cams...
Hello everyone, i realize there is a better place to post technical questions like this but i'm still in the "probationary period" i suppose and can not post anywhere else.
That being said, i'm wanting to do a cam swap on my 08 Heritage softail and i'm looking for advice. In the future (hopefully this winter) i will be doing the S&S 106 big bore kit. Until then, i would like to go ahead and upgrade my cams. I'm looking for low to mid range torque improvement. I'm also wanting a cam that will be beneficial in both 96ci and 106ci top ends. I really like the specs on the Woods 777 Cam, how well would it perform in both applications? I really don't want to do any head work, i'm fine with changing valve springs but i don't know any machine shop near me that i trust to port them. Another deciding factor for me would be if i could do these upgrades gradually with an auto tuner or would i be better off doing everything at once and have it dyno tuned?
So to summarize my questions are:
1. Best cam for a 106 kit (for low to mid range torque)
2. Would that cam work well in the stock 96 configuration
3. Is it worth doing the cam swap before Jugg swap?
4. Dyno Tuning vs a quality Autotuner
Thank you in advance, and have a blessed day!
Thanks a lot guys, for the most part I knew better than try to do it one piece at a time style. But my buddy just always has to rub it in my face that his 06 softail is faster than mine.
Would you guys suggest the Fuel Moto 107 kit over the S&S 106 Kit and why? I would like to run about 10.25 to 1 would i need the carillo pistons for that ratio? This will most likely be on pump gas (93 octane where i live) but i could also run VP110 that's what i like about the power vision, i could auto tune multiple files for what fuel i want to run and flash them whenever needed. Now i'm off topic
I really appreciate all the help, this forum is already my favorite!
