103 HO stock air cleaner filter: is it a high flow?
HO stock air filter
It it is not a hi flow filter. When you install a stage 1 use the k&n filter more air flow than Harley filter.
Received 4,843 Likes
Are you talking about the air filter element or the air cleaner assembly? In any case, the HO AC assembly is the Screamin' Eagle Ventilator, which is indeed a high flow "stage 1" assembly. And it does flow significantly more than the standard assemblies found on the non HO 103s, though not as much as the "Heavy Breather" assemblies that come standard on the CVO 110"s and the FXDL. It'll flow as much air as a 103 needs until you start producing some pretty stout horsepower numbers.
The reason why I'm asking is that I put Cobra slip ons on my '17 Slim, and have been using the FP3 canned map for a bone stock '17 Softail. The bike has been running and sounding great. But I noticed today that my FP3 has a canned map for:
I guesss I'm just wondering if that map might fine tune the mapping a bit better. But I wasn't sure if the stock air filter/element on a 103 HO was really a high flow or not.
