question about bolt strength 3/8
Hey guys! Its been a while huh!!!
i
have pics..i made forward control plates out of 5/8 steel plate... for my harley...i extended my foot controls 4" forward they utilize (3) 3/8 coarse bolts if i include the weight of the steel plate and include the weight of the floorboards its im going to say 40 -45 lbs probably less...am i maxing out the 3/8 bolt capacity closest to the frame?... Im concerned about vibration, etc my name is dennis thanks for all your knowledge also the left side kickstand is now 4" forward on the plate..think ill be ok?
i
Serious? I was worried didnt want to move forward my legs arecsyretched out nice but was worried..red loctite or frame bolts or lock washers? What you think fountain? Thanks bro i been up all nght with anxiety worrying man...lol im going to make a few sets for forum guys who want more foot room
Hey 82flh, not sure if you know but those lines on the bolt head indicate the bolt grade, and from that you can determine how strong it is. You have 6 lines on the bolt so that makes it a grade 8 bolt. One of the strongest bolts. You did good in not skimping out with cheap bolts. No worries at all about that thing going anywhere. Blue Loctite should be enough. Red needs heat to break loose. I use blue on anything that goes on the bike and never had a problem with a bolt or nut coming loose.
By the way, that is a hefty and solid piece or metal there. It takes some good tools to work a piece of metal that thick.
I only use red Loctite on internal motor/driveline parts I don't expect to touch again/can't reach, like the engine sprocket nut.
Everything else, I use proper lock nuts, lock washers or blue Loctite (rarely) as appropriate. Truth be told, as an tool designer/amateur mechanic, I'm more concerned with being able to take something apart "next time" than worrying about it coming loose.
For the record, I calculate the tensile strength of a 3/18-16 grade 8 bolt to be 11,500 pounds. The shear force is 7,000 pounds. I think you'll be okay.
