Motor oil on bottom of primary case
Old 04-19-2017 | 06:29 PM
rohdogflhtci's Avatar
rohdogflhtci
2nd Gear
Default Motor oil on bottom of primary case
I have a little motor oil on the primary drain plug and a couple bolts on the primary case. I'ts not even enough oil to drip on the garage floor when I come home and shut the bike off Hot. I switched to liqu-moly synthetic 10w60 from bel-ray 20w50 mineral oil...do you think I should go back to 20w50? I ride a 2005 electra glide classic with 44,000 miles and stage 1. Probly just gonna run it.
Old 04-19-2017 | 06:33 PM
Mr-Mike's Avatar
Mr-Mike
Did you use a new o-ring?
Old 04-19-2017 | 06:40 PM
rohdogflhtci
2nd Gear
Yes..I changed all 3 fluids with new o rings on each drain plug...it's not leaking at the drain plug.....the oil/tranny pan looks a little wet up higher....going to get it on my lift and have a look....funny I never noticed this enigine oil on the primary case when I ran Bel-Ray 20w50.
Old 04-19-2017 | 06:43 PM
dawg's Avatar
dawg
Look behind the inner primary to see if it might be a shifter shaft seal or another seal.
Old 04-19-2017 | 06:46 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 with the shift shaft seal.
Old 04-19-2017 | 06:55 PM
rohdogflhtci
2nd Gear
Thank you...I will check that when I put it on the lift tomorrow....I tried using a sight mirror with a light....but I need a better look.
Old 04-19-2017 | 08:21 PM
103 sedona orange's Avatar
103 sedona orange
Check your oil pan bolts. Good luck.
Old 04-19-2017 | 10:14 PM
DaddyKnuck's Avatar
DaddyKnuck
When you run out of things to check, check the bolts through the exhaust bracket on the transmission cover.
Old 04-20-2017 | 08:26 AM
heybaylor's Avatar
heybaylor
maybe the oil you spilled when changing filter has migrated back and down.
wipe it off and ride it some more
Hipolito
07-29-2018 08:29 PM
tmanbuckhunter
EVO
04-25-2014 02:49 AM
jamze_99
08-14-2011 05:44 PM
babyray
Oil Archive (no new posts)
04-19-2011 07:36 PM
fatguyona1000
08-05-2009 02:45 AM
Quick Reply: Motor oil on bottom of primary case
