geared cams
Old 06-04-2007 | 03:33 PM
jgallemore's Avatar
jgallemore
Stage II
Default geared cams
Any expeerience with this? Just went to a 2 into 1 exhaust on a 2006 Ultra Classic with a 95" motor with SE 203 cams. Bought the race tuner and had bike dyno tuned. Am going to install geared cams with as close as possible, the same size cams. Am I going to need a new dyno tune?
Old 06-04-2007 | 08:24 PM
cardboard's Avatar
cardboard
Default RE: geared cams
Why spend the extra money on the gear drive cams ?
Old 06-04-2007 | 09:27 PM
mp's Avatar
mp
No, you will not need a new dyno tune with the same cam, as long as it's installed correctly and not degreed differently. And I think you're better off with geared cams, as are all Twin Cam bikes.
Old 06-04-2007 | 11:18 PM
mentor70's Avatar
mentor70
Every bike is different, no two are alike! so any change in the breathing habbits will probably require a re-tune.
Old 06-05-2007 | 02:17 AM
Jovimon's Avatar
Jovimon
Andrews makes a kit to upgradeto roller chain/hyd. tensioners like the '06 Dyna's and '07 models, I'm thinking about this route instead of gear drive.
http://andrewsproducts.com/motorcycl..._Conv_cams.htm
Old 06-05-2007 | 01:29 PM
dstockton's Avatar
dstockton
ORIGINAL: Jovimon
I don't know the advantage here, it still uses chains with tensioners that can wear out. I think if I was going in, I'd go ahead with gear drive. The older EVO cam gear drive system is bullet proof. Harley only went to chain drive on the tc88 to reduce engine noise for EPA reasons. I've heard a few friend's gear drives running and unless you listen for it specifically you can't tell the difference.
Old 06-05-2007 | 01:42 PM
Clammy's Avatar
Clammy
I went with gear drive cams, and there is a barely audible whine (which I actually like - reminds me of the sound a blower makes on an old muscle car, albeit MUCH quieter!). I did it for a couple of reasons: reliability (no chain or tensioners to wear out, no maintenance required, and got better cam bearings) and more power (no loss in the chain system).
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
thewholehog
Exhaust System Topics
19
02-09-2013 07:57 AM
Sharkman73
02-02-2013 05:11 PM
rkbagger6
10-08-2012 02:12 PM
crazyanimal
08-16-2012 10:26 AM
jkrahn
06-12-2010 06:39 AM
