Ted from Toronto
Ted from Toronto
Hey guys not sure what exactly is going on, but my right ( brake side ) of my bike signals do not work. I am getting light out of them but no flash and no signal in the dash. Does this have something to do with the module? Does the module control one side or both side. Like I said the left side works the right flashers are only giving me light no flash. Fuse is good also grounded it out purposely,blew fuse just to see if there is continuity. I'm stuck?
Received 6,055 Likes
Ted,
Welcome to the forum from central Texas. As a helpful hint, whenever you post issues with your bike, mention the year and model of the bike. This will help us know if you have a TSM, TSSM, CanBus wiring, etc.
First, did you do anything to the electrical system prior to the problem or could there have been any unintentional changes to the signal wires? For example, did you disconnect the battery or open up the switch housings on the handlebars for any reason?
On most bikes, the front turn signals are running lights as well so they are dual filament. The rears, if not run/brake/turn, are single filament bulbs.
Anytime there are turn signal problems where lights aren't functioning as they should, the first thing to do is check the bulbs. Look at the filaments. You can take the left side bulbs, if they are working correctly, or any bulbs that you know work and put them in the right turn signals. Do the signals work correctly now? You can also put the right signal bulbs in the left signals and see if the same problem is now on the left. That will help rule out the bulbs as a problem.
Then look at wiring. Bad ground? Short to ground? Bad bulb socket?
Post back with more info as you test or the solution if you found it. Good luck.
I think Bone Doc hit the nail on the head, sounds like you've got a single filament bulb instead of a dual filament in its place. Either that or the 2nd filaments have burned out. I would start there first and carefully inspect your bulbs, the giveaway is if it has 2 contact dimples or 1 on the bottom of its bayonet type connector body.
Kirkg8
05-25-2013 11:42 PM
