pulling wires in bars
Use wire lube! My new bars didn't get reamed out very good when built n skinned some wires pullin thru the first time
so had to fix it. Ran stranded 18/8 (t-stat wire) n it was tight. Buddy is an electrician n started spraying the wire, I didn't think it was gonna work but sure as **** it did.
Depends on what bars and how many wires your trying to run on the sheathing .Help yourself by taking a dermal and deburring the dimples your feeding wires thru. I use electricians pull lube and guitar strings. I prefer D or G strings. As far as pushing or pulling that also depends on the bars shape. Your going to find it really hard to push wire thru a short set of Z-bars. I prefer to pull wires with a helping hand.
I cut an old throttle cable and routed the ball end threw. I then tie the cable to the wires with fishing line. Take electrical tape and tape all the ends to a point so it doesn't get snagged while feeding it threw. I then get a buddy to push and pull at the same time. I have wired a few standard apes and they are cake. Z bars need a little persuading but it will go
