alarm problems
Old 03-30-2017, 03:20 PM
jimjim's Avatar
jimjim
jimjim is offline
Stage I
Default alarm problems
how do i find the pin code on a 2004 sportster 883
Old 03-30-2017, 03:30 PM
upflying's Avatar
upflying
upflying is offline
Received 29,210 Likes on 12,052 Posts
One post and you are asking us to trust you? I am pretty sure a dealer is the only one who can reset it.
Old 03-30-2017, 03:40 PM
Mxdad's Avatar
Mxdad
Mxdad is offline
he is not asking how to reset it but asking how to determine his existing pin which can only be done with the FOB present.
With a 2004 I am guessing you have the push button FOB so you will use the 2nd method below
Setting or Changing Your Security System Alarm Override PIN
Button less fobs (Smart FOB)
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Push Button fobs
4. Press button on fob twice
5. Enter first digit of the new PIN by pressing left turn signal until the desired number appears.
Press button on fob twice to enter number.
6. Enter second digit of the new PIN by pressing left turn signal until the desired number appears.
7. Enter third digit of the new PIN by pressing left turn signal until the desired number appears.
8. Enter forth digit of the new PIN by pressing left turn signal until the desired number appears.
9. Enter fifth digit of the new PIN by pressing left turn signal until the desired number appears.
Turning the ignition to OFF stores the new security PIN.
Hero
09-13-2023 02:15 PM
'10 Wide Glide
07-11-2018 09:49 AM
Itay Frishman
11-09-2014 06:54 AM
dustin1014
01-04-2014 03:09 AM
0Nightster7
06-28-2010 07:32 AM
Quick Reply: alarm problems
