A Day in the Life...
#261
Received 4,199 Likes
Forecast of 5-7 inches of rain, flash flood warnings. Tornado watch, plus it's cold!
I borrowed the wife's truck to come into work this morning.
Did not feel like being this guy today!
Kevin
I thought so too.
Kevin
Kevin
I thought so too.
Kevin
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
#262
Received 4,632 Likes
I've been in water up to the headlight for well over 100', hoping it wouldn't get any deeper, hoping the motor wouldn't quit, and not daring to slow down because the carbs were behind the bow wave the motor was plowing and if I stopped, they'd be underwater. Was on a street bike, too, not trail bike. Getting in that deep was unintentional, but once you're in something like that, you're committed if you want a chance of getting out again. The guy I was following said don't worry, it isn't deep... That was when I was young and foolish and never thought about water in the wheel bearings... but they had separate seals then, and I lubed them fairly often anyway.
#263
Today is the big day we have been working toward for over 2 months!
We are moving our shipping facility from one location to another...it is only across the street, but every item on the shelves needs to be counted and then carried across the street to the new BINS.
Along with the move is a complete change in our inventory control software going into effect as we make the move.
I'm riding up to Memphis shortly to start counting. lol
We have over 20k parts that need to be counted.
Kevin
#264
#265
It was a LOT of work!!!
Kevin
The ramp up into my bike room has been getting a few soft spots in it, and one spot that had collapsed...
...it made it a bit "fun" when going down the ramp if one of the tires got in that "low" spot.
The problem was that we did not paint or protect the wood where it was in contact with the ground...so it just soaked up the water and got mushy.
The frame is actually quite strong, and in good shape...
...although I did go ahead and put a couple more supports in it, and paint the exposed surfaces.
I'm also replacing the 5/8" plywood with 3/4" plywood.
Yesterday afternoon we stopped after giving the plywood a good heavy coat of paint.
This afternoon I will be putting plastic edging on the bottom edge of the plywood, so that when water is setting, it will not get into the wood. Then attaching the plywood to the frame, and then putting some new roofing material on it.
By tonight I should be able to get my bikes out of the bike room where they have been stuck.
Kevin
Kevin
Kevin
#266
The roofing material should make a good non-skid surface, but do you think it will hold up to being ridden on? Cheap enough to replace every year if need be, though. Sounds like a good idea.
I just got a trailer last week, and before I use it (and leave it parked in the back yard - in the garage now), I'm painting the wood deck with skid resistant paint. Only put the sidecar rig on it to check out fit, plenty of room on a 6x10. Sanded it yesterday and taped off the frame next to the wood, should be able to paint it today. Got too hot in the garage with the door closed yesterday, and was raining outside.
Even though this Ural has been trouble free - so far - I feel a little nervous about having it break down (they're kind of famous for that, although that might be like Harleys leak oil ) when it won't fit in most rental trailers, or the ones my friends and neighbors have. It's not a highway bike, either, rpm gets near redline at 70, so for a couple of extended trips I'm planning this fall this "mod" will let it cruise as fast as my pickup truck. I doubt my 8 year old grandson would like spending several hours in the sidecar, too. My daughter would also like to carry some trail bikes to Wisconsin occasionally for off roading; none of that around here. Only have one trail bike with a dead starter right now (what fool decided carburated trail bikes don't need a kick starter?), but she wants to get her son a small one. I like riding off road better than pavement myself. Except on a Harley hard tail, did that once...
#267
The wood only got wet were it was sitting on the ground, and with this new rendition, that won't be happening anymore.
Kevin
#268
Wow! Not sure what's up with the weather...but it has been a very mild summer for us...and last night was in the low 50's!
This morning was the first time I've worn my leather jacket in many months.
Looks like it will be in the 50's each morning on the ride in for a while. Crazy for us at this time of year.
#270
