Strapping down motorcycle in trailer
I have a 7'x14' enclosed Golden Gate trailer that I am going to be hauling my SGS into if needed. It doesn't have anything in it installed hardware wise to attach the straps to, just bare wood floors and walls. What do you guys have in your trailers to strap your Harley down? I was looking at the E-tracks or just regular tie down anchors, but with the anchors i am going to have to drill holes into the floor for them to sit. I also do not want them to pull out of the floor and let the bike fall. Whats your guys opinions. Oh and I will have a wheel chock for the front.
Received 14,670 Likes
boston jim (03-18-2017)
I have a Smart Chock in my trailer and it along with the tie-down rings are anchored to the floor with steel plates underneath the floor. I have traveled extensively with various bikes inside and never had a problem. I watched a youtube video today on the BW Biker Bar. Check it out! If I had known about it beforehand I probably would have gone with that setup. Harley has some good ratchet style tiedown straps.
http://www.trailersniagara.com/trail...art_chock!.htm
RKLobo
RKLobo
Go and get some 1/4" steel plate cut into four 4"x 8" rectangles, two for the top of the floor and two for the bottom under the trailer and have them drilled or machined to accept the tie down bracketry. Then install them in/under your trailer about five feet apart where you want to put your bike. Use some silicone caulking on the underside steel as a gasket to help keep the moisture away from the wood floor where you install the plates. You can use the same idea to install a wheel chock if that's the way you want to go.
Mr Fixit (03-19-2017)
Another thought, and you can call me **** if you want but this is something I do if I have to trailer my bike. I put two eyebolts into the floor on each side of the bike. Using two separate soft straps on each side of the bars, I use two ratchet straps on each side of the front of the bike. In the event that a strap or eyebolt somehow fail, I want to be covered instead of chancing any damage to my bike. Just a couple extra bucks and a extra 5 minutes you just might not regret sometime.
