You using "Ride-On" in your tires
Old 03-12-2017, 10:55 AM
luc.who's Avatar
luc.who
luc.who is offline
I hate wheel weights. I was using dyna beads and with my last set of tires went to ride on. I have about 8k miles on the tires and am very happy with the balance. Run the bike hard and often cruise at 80.
Old 03-12-2017, 10:57 AM
r2t2k2's Avatar
r2t2k2
r2t2k2 is offline
It balances the wheels and I can say that it sealed around a large screw that was in my rear tire. We suspect that the screw had been in the tire (almost dead center) for quite a while as the head and part of the shaft was ground down. I have it put in all my motorcycle tires.
Old 03-12-2017, 12:06 PM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,633 Likes on 1,628 Posts
i put Ride-ON in every motorcycle tire i've owned. works very well.
Old 03-12-2017, 12:27 PM
larsfum's Avatar
larsfum
larsfum is offline
Another happy Ride-On customer here. Second set of tires (with tubes) with it in. Does a nice job of balancing the tires. Have not needed to use the stop leak feature.
Old 03-12-2017, 12:41 PM
HKMark23's Avatar
HKMark23
HKMark23 is offline
Received 1,940 Likes on 1,116 Posts
I'm thinking I might just have to turn a drill into my existing rear tire right before replacement just to see how the stuff works.
Old 03-12-2017, 12:43 PM
nobodyknowsme's Avatar
nobodyknowsme
nobodyknowsme is offline
Received 14,670 Likes on 6,425 Posts
Judging by how the screw head was worn in the rear tire of one of the bikes a couple years ago, it surely saved me some riding time. When it was found I put a mushroom plug in it and was able to get the remaining life out of the tire. Have used it at least the past dozen tires and will not have rubber mounted without it.
Old 03-12-2017, 02:00 PM
0maha's Avatar
0maha
0maha is offline
Received 4,679 Likes on 1,665 Posts
Decided to try it this go around, but my bike's still in pieces with my annual winter maintenance/upgrades.
Tires ready. Looking forward to seeing how it works.
Old 03-12-2017, 02:21 PM
SWThomas's Avatar
SWThomas
SWThomas is offline
Received 1,108 Likes on 663 Posts
Yup. Great stuff.
Old 03-12-2017, 02:23 PM
SPRINGER's Avatar
SPRINGER
SPRINGER is offline
Received 3,270 Likes on 1,976 Posts
Yes, been using it for years, it's duo purpose, it acts as a sealer and also balances the tire.
Old 03-12-2017, 03:07 PM
lmar's Avatar
lmar
lmar is offline
Received 2,073 Likes on 2,055 Posts
I don't use it, but I carry a plug kit and small,air compressor.
Quick Reply: You using "Ride-On" in your tires
