Battery
Received 4,632 Likes
After seeing hoverboards, cell phones, and even a pair of headphones ignite (while they were still on a lady's head), I would wait for the lithium technology to improve safety before I put one in something I care about.
You know...like what should have been done BEFORE they went to market.
This new tech uses a solid lithium bar instead of the alloy used in current types, but for reasons I couldn't explain this would burn in liquid suspension. A byproduct of the new tech is supposed to be nearly double the charge capacity, sounds like it would be the greatest thing yet for vehicle batteries and especially for electric vehicles. Until this becomes available, I'll stick with lead acid, and carry my tiny lithium jumper battery - which I would with a new Lithium main battery anyway. I sure miss kickstarters, wish they'd kept them on carbed bikes (all of mine).
An AGM for less than $32? Something bad has got to happen here. Just for grins I put one in the cart and went to checkout. There doesn't appear to be any shipping charges for this one.
http://www.batterysharks.com/Deka-ET...FR2Hswodq08Bng
My Indy told me one time "when you buy a new cycle battery, put its electrolyte in it, and and let it set for about an hour, then finish charging it up, because cycle batteries come from the factory half charged." He also told me that "if you put the electrolyte in it and put it right straight on the bike, the second you hit the starter button you just killed one third of your batteries life." I have no idea whatsoever, how this post relates to where to buy a battery from, but I thought it might help some one.
Saw a show on PBS about Lithium tech. Current tech Li batteries use a liquid the anodes and cathodes are suspended in, and other than that I couldn't explain more, but simply drive a nail through one, and you can have an instant blowtorch, and if the charging circuitry in the battery itself has a flaw... meltdown or blowtorch. There is a new technology that replaces the liquid with a plastic that passes ions, and they showed nails, drills, hammers and metal shears used on it with no problems. The battery even still put out voltage when cut in half.
13RoadKing
Electrical/Lighting/Alarm
02-11-2017 02:31 PM
