First oil change completed..well, almost.
Old 05-31-2007 | 12:05 PM
oldgeezer's Avatar
oldgeezer
Default RE: First oil change completed..well, almost.
If you don't have an owners manual for the bike, get a service manual even if it is a Clymers. Thattaway, you'll know for sure. At any rate, always check the oil shortly after you've run the bike since you need to check it when most of the oil is still in the tank.
Old 05-31-2007 | 12:10 PM
michaelbarry's Avatar
michaelbarry
ORIGINAL: oldgeezer
Well, i'd love to be able to just buy the factory service manual, BUT I lost my job (eliminated my department) and so i'm just doing all I can to keep my bike at the moment. [&o]
Old 05-31-2007 | 12:14 PM
zukeeper's Avatar
zukeeper
you check an evo on the stand for engine oil , upright for the other two holes. like the others have already said , should take around 3 quarts
Old 05-31-2007 | 12:19 PM
michaelbarry
Alright, so on the stand it is. Thanks a lot guys..[&:]
Old 05-31-2007 | 04:52 PM
fxstcguy98's Avatar
fxstcguy98
My owners manual says to check the oil with the bike level for the fxstc 98 EVO
Old 05-31-2007 | 05:01 PM
anubisss's Avatar
anubisss
Ok, check it on the side stand, pour a couple of quarts in, plug the hole and run the engine for a minute or so. Check the level again and fill until at the desired level. People say to pour a couple of ounces into the oil filter prior to screwing it on. Only tighten the filter hand tight, not with the wrench. Lube the rubber gasket of the oil filter with clean oil prior to screwing it on. Pretty simple. I understand losing your job, jsut went throught that myself. For the tranny, check it straight up and down, as well as the primary...
Old 05-31-2007 | 06:19 PM
Tnicean's Avatar
Tnicean
It seems like you can't depend on how other bikes are checked.My 2002 Heritage Softail Classic's manual says to check theoil hot with the bike level. My buddy's 2005 RKC says to check it on thejiffy stand hot. I hope someone with a 97 fatboy will answer your question. Anyway,as long as you can see oil in the oil tank, you are not goingto hurt it. I cancheck mine by looking in the oil tank. If the level is at the weld on the filler neck, it isfull.
Good luck,
and sorry about the job and hope you get anotherone soon.
Tnicean
msengel
05-11-2024 08:50 PM
Highgrade
03-12-2016 10:53 AM
fortyeight_408
03-10-2013 11:32 AM
Falcon195
07-17-2012 10:57 AM
Toplink
11-12-2008 10:13 PM
Quick Reply: First oil change completed..well, almost.
