Tubed Tire Change Questions
Received 4,627 Likes
Some folks think they're good to go if they still have tread. I bought one in 2013 that had a '93 tire on it. Rode it home slow and easy on slower residential roads. Lightweight dual purpose Yamaha with knobbies and rim locks on the wheels, wouldn't have even tried that on a Harley, would be a trailer home with a tire like that.
9 years on the tire, you got your money worth and ran it several years longer than I would feel comfortable. As far as the tube and rim strip, you are talking about low cost items than one could debate either way when tires are being changed out every year or two, but seeing as you go up to 9 years on a tire then changing them each time should be an automatic yes
What helps, too is to get some baby powder (the kind with talc) and sprinkle it over your tube and some inside the tire before mounting it. Prevents the tube from sticking and makes it easier to install. Go to target or walmart or something and get the little travel size baby powder for cheap.
