The EFI system is disappointing me
#51
I have a snowblower.
I noticed on days I use the blower I don't ride. Coincidence?
MikerR1, aren't you under warranty? Gas I guarantee is not an issue
#52
Cold front came through here, too. Bike ran like a raped ape with a bent banana. That's the advantage of EFI. Something else is amiss with your sled.
#54
There is absolutely no substitute for a brand new deck of Bicycle playing cards. My suggestion is, stop using those cheap convenience store brands and stick with high quality playing cards for that authentic, no compromise performance.
#55
Gotcha. Well, again, the Powervision works just fine on that bike, and even though you still haven't answered, I assume it has stock pipes.
Pictures of your bike?
#56
#57
#58
I'm counter leaning that something is amiss here. Take the 2016 by the dealer for them to evaluate. I have an early EFI system, 20 years old now, that I do enjoy.
If the bike runs better on Sunday are you wearing your Sunday-go-to-meeting cloths, or are you wearing your Sunday-out-to-be-a-pirate gear.
One thing to consider since you let a tank of gas sit for 5 days is to use the maximum amount of Sta-Bilt for the amount of fuel remaining.
In other words if you have a 5 gal tank and ride all weekend leaving 4.75 gals left just use the appropriate amount for 5 gals. Add some octane boost the following weekend.
#59
I know the ECM has something called "adaptive learining". Which, I think, means that the system will keep track of the amount of fuel it has to add or subtract for each cell in the map. This causes the map to get better with time. My understanding was that the adaptive learning does not reset unless you disconnect the battery. For instance it does not reset when you turn off the bike. However, the order you do things on the bike may be important. You may have to turn the bike off by first turning off the stop/run switch and then the ignition switch, to make sure the learned results are saved. If you turn off the ignition switch first, before turning off the stop/run they may not be saved. But this is all speculation. I really do not know. I am wondering if there is some time limit in the ecm that if the bike is not turned on for x number of days all the adaptive learning data is reset. I do not know yet.
Having said all that, MasterTune (the guys who wrote the original SERT software) have said that one should turn off the ignition switch before the stop run switch. He says that the ecm also learns the zero point on your throttle via adaptive learning. That article says that if you use the stop/run switch to turn off the bike you might be twisting the throttle a tiny bit at the time you turn off the bike and the ecm may be learning that the idle position is not exactly at zero. He says the symptom of this is the idle will gradually creep up with time.
Here is a link to the MasterTune article. Scroll down to the bottom "Electronic Throttle High Speed Idle"
http://www.mastertune.net/support_tuning_problems.html
#60
oh god, no. only 1 debate at a time, please
