High Speed Cruise Control
High-speed cruise control usage
Today I was on Texas State Highway 130 south of Austin. It is a toll road with an 85 mile per hour speed limit. When using cruise control I found it would not work past 83 miles per hour. I would bump the cruise switch on the right side to increment the speed 1 mile per hour, several times, but it did not seem to react. The bike would go up to 90 manually,, but the cruise not reach 90. Is this normal?
I have a 2003 FLHRCI.
I was told by a salesman, the cruise control was set to a maximum of something much lower than that.
I found that I can lock the bike in way HIGHER like into the 90's and consistently. And with the different bikes I had. (Cruising bikes.)
I regularly lock it in at 82 mph which is my cruising speed on my Ultra Ltd.
So I would guess, YES it is normal.
BuzzCap7
BuzzCap7
I've been on that same stretch of 130 around Austin several times. Most recently was about a month ago and both my wife's 14' Road King Classic and my 11' Road Glide Ultra running about 90 with cruise controls set. That being said I honestly don't remember if I got to 90 and set it or used the 'bump' method to nudge it up after initially setting it.
