Seems like I have strong exhaust smell when I stop at a light or stop sign. The inside of my exhaust is black with carbon. I checked my plugs and they look good and tannish white. Should I adjust the air/gas mixture at the bottom of carb make it a little leaner?
No I'd leave it. My pipes are sooty inside, too. As long as there's no bogging, hesitation or bad plug readings, you're good. I'm running a S&S Super E on my Evo.
If you only notice it at idle, might try leaning out the idle mixture a bit. Check that the float valve is closing at the right level. Too high could cause a rich at idle state.
