2011 street glide front wheel on 08 eg
Starting in 2008 they starting using the 25mm front axle.
Since the 08 had the Brembo brakes the 2011 wheel and rotors are a direct swap and using your spacers as well.
**** NOTE****
Is your Bike ABS?
Does the Wheel you bought come from a ABS Bike.
If no on both its a direct swap.
If your bike isnt ABS and the wheel is, a bearing swap is in order.
If your bike is ABS and the wheel isnt ABS a bearing swap is in order.
**** NOTE****
Is your Bike ABS?
markfrommn
Wheels/Tires
08-20-2011 04:20 PM
