HD LED mirrors
HD LED mirrors
Has anyone installed the HD led mirrors where they work as a running light and turn signal? The instructions are ridiculously vague and are designed to leave the original turns connected as well. Im looking to only have the mirrors and remove the stock turns. Being imstalled on a 2014 night rod but i think they should all be roughly the same.
Thanks
Thanks
Thanks
Thanks
The y harness supplied does the trick. The tough part was deciphering the instructions and then adapting them to not reattaching the stock turns. I had to Google a wiring schematic so I knew what colors were what on the stock harness then mirror those colors with the wiring in the harness although the colors in the harness are not the same.
For future use, the stock wiring harness colors are
Purple(left)/brown(right) = turn signal
Blue = running
Black= ground
Blue = running
Black= ground
Join date 9/16 and 5 posts? Let me guess, you like to talk chit rather than give some experienced input?
