Chatter only during acceleration
I have a Revtech 100, mikuni 42, any speed under load acceleration. there is a chatter as soon as slightly letting off throttle it stops...had idle a bit low and it seemed worse, brought the idle up just a bit and seemed better...Any Ideas or direction be appreciated...
Received 24,478 Likes
May also be pre detonation (knock sensor / carbon build up / bad fuel / carb not jetted correctly..., jets gummed up / plugs too hot)
Try changing the oil and adding seafoam to the gas - run a tank or two thru to see if it improves
More detail would also be helpful - this chatter - just start..., or been this way for awhile
What was done to the motor just prior to it chattering
Ghost
Ghost
It's your ol' lady on the back telling you to slow down. Not sure what you mean by chatter but if you are talking about pinging I agree that octane booster is the first thing to try before you destroy your engine. If that helps then maybe a top end tear down is in order to diagnose the problem. What compression ratio are you running?
Dan
Dan
