wide glide front tire wear faster than rear
my 2012 wide glide has 11k miles on the stock michelin scorcher 31's. The rear still has lots of life, but the front is down to the wear bar. it has even wear and nothing abnormal besides how much quicker it wore out than the rear. anyone else get this? haven't found very much at all on it. everything else I own the rear goes quicker, but then again the front is tiny I these wide glides. just ordered a 90/90/21 for it last night.
You should stop by the Dyna Forum
Pretty common with the Wide Glide; frame geometry is part of the reason. The trail can cause a shear effect at the contact patch as you turn in, the front has less tendency to roll causing earlier wear. The overly soft suspension and front end dive is also a factor in the accelerated tire wear.
Upgrading your front forks with a heavier fork oil and better/heavier springs will help not only with improved handling, but the front tire wear.
You'll love the Pirelli Night Dragon; they're all I use
One thing to add: Be mindful of your tire pressures with the Dragons. People who run their front too low report having scalloping/cupping problems and handling issues when cornering. The more rounded profile of the Dragons and lower tire pressures don't seem to mix well.
I've found 39 - 40 PSI on the 90/90-21 front and 42 - 43 PSI on the rear 180/60-17 Night Dragons give me the best handling and tire wear.
thanks for the replies, thats good to hear. I thought maybe because it was smaller ot might wear faster, but wasn't sure. anyways the tire I ordered last night is the pirelli night dragon. wish I had the cash to do the front and back right now, but the back still has life so I have to wait a bit.
Running a Scorcher on the rear and a Night Dragon on the front do pay attention to how the bike falls in to corners. The Dragon has a more rounded profile and wants to fall in, the Scorchers profile is much flatter and doesn't want to fall in as well. I've always changed out my rear tires when I change out the front, I've used the front as my gauge as to when front and rear tires are changed out. Be mindful of the profile differences, that Dragon wants to fall in to a corner; the Scorcher, not so much
