Removing front signals for powdercoat
Old 06-29-2016 | 02:32 AM
Rollcage's Avatar
Rollcage
Default Removing front signals for powdercoat
So I'm wondering if anyone here has done this. I already pulled my rears, but am reluctant to do the fronts.
I know inside the switch housing, the wires are zip tied to the switch wiring, and I know how to remove the pins from the connectors under the tank.
However my two concerns are feeding the wires back through the black wrap that hold all the wires inside the handlebars, and I'm still not sure about the "flat" wire casing that goes from the switch, to the signal housing itself.
Can anyone chime in on this??
Regards
Rollcage
Old 06-29-2016 | 03:06 AM
Next In Line's Avatar
Next In Line
What bike?
Feeding the wiring through the bars is simple:
Take a piece of nylon rope and put it though the bars (compressed air works great).
Take the wiring to the rope.
Slowly pull on the rope while pushing the wire from the other side at the same time.
Old 06-29-2016 | 03:38 AM
Daddy454's Avatar
Daddy454
I did mine when I installed my apes.Wasn't too hard to do,but I also moved them off the bars at the same time.Not sure if you want them there,but may be a good time to think about a relo.
As far as running them through the wire wrap,you could probably just make a separate harness for just the sigs,and run them alone instead of running them back through the stock harness.
Rollcage's Avatar
Rollcage
2014 FXDF
Running the wires up through the bars isn't my primary concern, I figured I could do it with fishing line. But the wires for the switches, and the signals are all contained within on casing.
I'm sure it's just to protect them more than insulate them, but I don't really see getting the signal wires out, or more specifically back in, without cutting the casing open.
Also, as stated, the wire casing from the signal to the switch housing is a "flat" casing, I don't understand how the wire and pins would go through them without being cut.
Old 06-29-2016 | 03:43 AM
Rollcage's Avatar
Rollcage
I have thought about this, but to be honest, I like the look and location of them on the bars.
I know I'm probably the only person EVER that prefers them there, but hey different strokes.
Old 06-29-2016 | 03:49 AM
Daddy454's Avatar
Daddy454
Take the sig off,cut the wires inside the housing,PC housing,then splice inside the housing.Just did this to my boys bike when we put new sigs on his.Minus the PC part.
Old 06-29-2016 | 11:39 AM
multihdrdr's Avatar
multihdrdr
Old 06-29-2016 | 11:49 AM
bigred333's Avatar
bigred333
Would this work?
- Carrie
Old 06-29-2016 | 11:51 AM
Rollcage's Avatar
Rollcage
Originally Posted by bigred333
Would this work?
- Carrie
That's EXACTLY what I'm thinking!!!
Old 06-29-2016 | 11:59 AM
multihdrdr's Avatar
multihdrdr
Did I miss something...why don't you split the housing and unplug the connector. Doesn't that terminate in the housing?
Quick Reply: Removing front signals for powdercoat
