Exhaust Gasket Question
Hey All,
What's the consensus on gaskets for aftermarket pipes like Vance and Hines? I know mine came with SE style thinner ones. V&H strictly says to use these style gaskets. However it seems some use OEM And prefer them. Where I'm confused, is why would V&H tell you to use a specific style yet some seem to install the OEM kind? Does it do harm if you use the larger OEM gaskets?
the se ones are smaller, and give a better flow for the exhaust. It doesn't matter which you actually use, You're not drag racing. I have had sets of pipes that wouldn't seal with the SE ones and had to use the bigger gasket, something about the pipe fit, I guess. I would initially use the se ones, If no problems, then, don't worry. Its not like the bike is going to blow up! Its an exhaust gasket, don't overthink it!!
It's not about "stock" or "aftermarket" it's the shape and there are 2 different styles.
Wedge and Flat.
My knowledge is only 06 or better twincam A engines. The factory pipes have a distinct wedge shaped end or "nozzle",,( the end that enters the head). The stock gasket is wedge shaped to best accommodate the end. These are available as either HD or aftermarket.
Other styles of pipe like Screaming Eagle and many other "aftermarket" pipes don't have that shape and are inserted to the head and gasket as "flat".
HD stocks "Screaming Eagle" gaskets that are flat as well as many other "aftermarket" dealers.
So "Wedge" or "Flat",, which works best??
It really has to do with the installer and his technique,,both will work.
If your in a panic about your install, (yet) buy a punk stick, incense stick or light a cigarette an hold the free flowing smoke from the end of the above said smoke pudge near the head exhaust port, exhaust gasket and flange,, you will "see" if it's leaking.
Wedge and Flat.
this is what I'm talking about and why I was asking. Good replies and knowledge here. The reason I'm asking is because the bike doesn't seem to pull any harder.... if anything it's less pull down front but that could just be my lack of riding over the past month and forgetting. So was thinking maybe there's a little leak robbing me of a few hp haha.
Regardless of what style gaskets you use it is most important to get them seated into the exhaust port correctly. After having much difficulty trying to simply line them up and push them in by hand I finally figured out the correct method for getting them to seat properly.
I have a 36mm socket that has an OD of 1.85" and it is a perfect size to install the gaskets. Just get them started by hand then use the socket to push them in until they seat. You can use your 1/2" drive extension as a handle once they are started. They go in straight and seat flush to bottom of port every time.
However having said that, I still would use the manufacturers recommended gasket. I'm running a V & H True Dual header and use the S/E gaskets.
