Heads Up For Hammock Seat Owners
I've been doing a seat mod on the wife's seat and figured while I was at it I'd add a little to the rear of the bucket of my seat because I've been getting some of the dreaded tailbone pain on longer rides. I just figured the padding had broken down some over time since when I first got the seat I could ride all day and still feel like I was sitting on my couch. Well, if you have a hammock seat like I do and have been experiencing the same thing then next time you have it off, flip it over and give the underside a look! Here's what I found. The section of the hammock sling toward the rear of the bucket had come undone.
Now the good news is it didn't go far and it's not that hard to get it back in place. Pull the staples on the flap of cover and then grab it with a pair of needle nose pliers and work it back into the groove. It is only retained by two flex tabs that I'm sure it just worked its way past over time and due to flex in the pan. I pre-drilled two holes and ran a screw into each to help keep it in place. This location allows the screw to go through two sections of the pan and the bar.
Should be good as new and as soon as the rain stops I'll be making sure.
The following 6 users liked this post by Little Mike:
almostakeeper (03-25-2020),
Bafflingbs (09-08-2020),
Greg2012FLHTK (09-08-2018),
Gunrunner72 (05-25-2016),
rwven (11-18-2016),
and 1 others liked this post.
For a $500 seat this shouldn't be happening. More crappy Moco engineering.
suprdave04 (05-27-2021)
Thanks for the post
I thought it was imagination that my tail bone started to get sore all of a sudden. Sure enough .. Unslung hammock
Mine was almost all the way retracted into the pan and I really couldn't get it with pliers
I pulled a lot staples and got my hands in between the foam and hammock and helped the plastic bar make the 90 degree turn up back into the slot. Still took some finnagling but it worked.
If you are struggling .. Just pull the staples and make it easier
waldoe (10-08-2022)
My Heated hammock on my 16 RGU is only 7 months and 4,000 miles old. I noticed lately my but wasn't stay all the way back in the seat, I was sliding forward and the seat felt spongy. I just saw this thread and went and pulled the seat. Mine looked like the 1st picture in the 1st post. I was able to use long nosed pliers and pull it back up and on top of the plastic tabs. Drilled the two holes and put in sheet metal screws. Now it feels like it did new. Thanks for the info.
