2003 screaming eagle road king question
I recently purchased a 2003 screaming eagle road king with 15,000 miles on it..someone told me I should think about replacing the cam tensioner with a hydraulic one..I was under the impression the screaming eagle already had a hydraulic one??..and if not is the milage about right to replace it?..im very mechanically inclined can I do it myseld?..cost?..thank you in advance for any help
I'm gonna check this weekend. .thank you..I see different options if needed to be replaced..I can't afford the upgrade right now but I also see on j&p cycles they sell an upgraded replacement shoe only for the stock tensioner. .has anyone have any thoughts on those ?..it's either that or a HD stock replacement
http://www.harleydavidsontensioner.com/
You can use stock or Cyco brand, they seem to be a bit better than stock....if you are a low miles rider I would leave them alone for at least another 7500 miles...so he say after the first change the chain is polished and the 2nd set lasts longer??? Not sure if it's true but you would gave at least another 25000 miles, if that's enough miles for you then that would be peace of mind.
Scudda
08-02-2014 05:15 PM
swampking
05-09-2008 09:59 PM
